scary lifting of my car
I just wanted to let you all know of an interesting experience I had jacking my car up today. I had raised the driver's side and it was sitting on jacks and then I raised the passenger side on the forward jack point and then slid some jack stands under the car. As I was lowering the car onto the jacks, that forward jack point collapsed and the car fell onto the jack stands. Good thing those stands were there! Thankfully I am fine and injure free but I wanted to just remind everyone to be very careful jacking up these or any car.
-Daniel
Yea, no kidding be careful! Wow. You obviously had your Lucky Charms for breakfast today.
Can you tell more about the type of jack you were using? Was it a hydraulic floor jack or the spare tire jack?
It was a hydraulic floor jack. I have been using it pretty regularly the past two years jacking it on the same point and have had no problems but the metal just crumpled this time.
Side load is a jacks worst enemy. I'm glad you're ok.
Daniel - Just to clarify... you said the "forward jack point" collapsed. You mean the jack itself lost hydraulic pressure and suddenly collapsed - as opposed to the jack point of the car itself? Were you jacking on a level surface?
Glad to hear you are ok!
Was this the jack point you used?
[Image: abcd0030-640.jpg]
Could you post a picture of the collapsed jack point?
I have heard of welding new jack points onto older Porsches. I wonder if ours can be replaced?
When I lift the 968 for working under it I use two jacks and with her assistance lift both sides of the car at the same time. Typically I start with the front which I place on stands and then move to the back.
Many of us have real expensive jacks. I have three Craftsman jacks and a Walmart jack. The Craftsman jacks were purchased on sale for $30 each and came with four 2 & 1/4 ton jack stands. In total I have six jack stands. The third Craftsman jack is similar but in a travel case. With Six jack stands and two jacks under the car I feel pretty safe working under there.
When I change from street to track tires I use a single jack under the rear jack point which will lift both tires on a side for changing.
[quote name='BruceWard' date='Sep 4 2005, 05:17 PM']Glad to hear you are ok!
[right][post="9514"]<{POST_SNAPBACK}>[/post][/right][/quote]
My rear passenger side jacking point has been squashed by a previous owner so I have ordered a replacement from Germany through Porsche GB and will have it fitted in a couple of weeks time when my car goes in for service.
I will let this forum know how I get on.
Cheers Shaun........London UK.
Yes Bruce that is the jack point that I used. And not it was not my jack that collapsed it was the actual metal of the car that bent and collapsed. Maybe I should just get some air jacking in my car like a LeMans race car; that would solve everything!!
-Daniel
[quote name='blk968' date='Sep 8 2005, 06:19 PM']Yes Bruce that is the jack point that I used.  And not it was not my jack that collapsed it was the actual metal of the car that bent and collapsed.  Maybe I should just get some air jacking in my car like a LeMans race car; that would solve everything!!
-Daniel
[right][post="9642"]<{POST_SNAPBACK}>[/post][/right][/quote]
Bruce....Does your picture show the front or rear jacking point..?
Cheers Shaun.
Daniel,
Could you check for rust and post some pictures. That is a crazy thing to happen.
-vinay
Shaun,
That picture is the front jack point.
Here is another [Image: dscn3110-640.jpg]
I use a piece of 2x4 under the floorpan to spread the weight onto a jack stand. The 2x4 has grooves cut into it so it fits in the saddle of the jack stand.
This is a picture at the rear
[Image: dscn3112-640.jpg]
On the rear I use a smaller piece of wood between the jack stand and rear suspension
[Image: dscf0015-640.jpg]
[quote name='BruceWard' date='Sep 15 2005, 04:43 AM']Shaun,
[right][post="9895"]<{POST_SNAPBACK}>[/post][/right][/quote]
Bruce...Thanks for the reply and pics. I wonder whether you could show a close up pic of the rear passenger side jacking point ( lit-up if poss ). This will prove usefull for my garage to replace my squashed and distorted one next week.
I have noted your method of jacking up and using the axle-stands so as to protect
the underbody and for safety. Many thanks again.
Cheers Shaun.
Shaun,
Let me know if these help. There are a few more at http://968.2ward.com/index.php?ALBUM=ServiceAndRepair . If not I can grab the camera and get a few more.
[Image: dscf0014.jpg]
[Image: dscn3112.jpg]
Last Post by 968rz
05-20-2008, 10:57 PM
Last Post by doggonit
03-29-2008, 08:18 PM
Last Post by bob blackwell
10-29-2007, 07:25 PM
Last Post by Renalicious
05-30-2007, 02:34 PM
