Threads: 51
Daniel - Just to clarify... you said the "forward jack point" collapsed. You mean the jack itself lost hydraulic pressure and suddenly collapsed - as opposed to the jack point of the car itself? Were you jacking on a level surface?
Threads: 5
Glad to hear you are ok!
Was this the jack point you used?
Could you post a picture of the collapsed jack point?
I have heard of welding new jack points onto older Porsches. I wonder if ours can be replaced?
When I lift the 968 for working under it I use two jacks and with her assistance lift both sides of the car at the same time. Typically I start with the front which I place on stands and then move to the back.
Many of us have real expensive jacks. I have three Craftsman jacks and a Walmart jack. The Craftsman jacks were purchased on sale for $30 each and came with four 2 & 1/4 ton jack stands. In total I have six jack stands. The third Craftsman jack is similar but in a travel case. With Six jack stands and two jacks under the car I feel pretty safe working under there.
When I change from street to track tires I use a single jack under the rear jack point which will lift both tires on a side for changing.
Threads: 2
[quote name='BruceWard' date='Sep 4 2005, 05:17 PM']Glad to hear you are ok!
[right][post="9514"]<{POST_SNAPBACK}>[/post][/right][/quote]
968 Coupe Tiptronic.1992 Metallic Slate Grey.Japanese Import.Sport Classic wheels.Goodyear Eagle F1's.Janspeed sports exhaust,M030 brakes,Air-con,Promax Chip,K&N Filter.
Threads: 2
My rear passenger side jacking point has been squashed by a previous owner so I have ordered a replacement from Germany through Porsche GB and will have it fitted in a couple of weeks time when my car goes in for service.
I will let this forum know how I get on.
Cheers Shaun........London UK.
Threads: 2
[quote name='blk968' date='Sep 8 2005, 06:19 PM']Yes Bruce that is the jack point that I used. And not it was not my jack that collapsed it was the actual metal of the car that bent and collapsed. Maybe I should just get some air jacking in my car like a LeMans race car; that would solve everything!!
-Daniel
[right][post="9642"]<{POST_SNAPBACK}>[/post][/right][/quote]
Bruce....Does your picture show the front or rear jacking point..?
Cheers Shaun.
Threads: 5
Shaun,
That picture is the front jack point.
Here is another
I use a piece of 2x4 under the floorpan to spread the weight onto a jack stand. The 2x4 has grooves cut into it so it fits in the saddle of the jack stand.
This is a picture at the rear
On the rear I use a smaller piece of wood between the jack stand and rear suspension
Threads: 2
[quote name='BruceWard' date='Sep 15 2005, 04:43 AM']Shaun,
Here is another
[right][post="9895"]<{POST_SNAPBACK}>[/post][/right][/quote]
Threads: 2
Bruce...Thanks for the reply and pics. I wonder whether you could show a close up pic of the rear passenger side jacking point ( lit-up if poss ). This will prove usefull for my garage to replace my squashed and distorted one next week.
I have noted your method of jacking up and using the axle-stands so as to protect
the underbody and for safety. Many thanks again.
Cheers Shaun.
Threads: 5
