I ran into a problem yesterday while trying to revive my TS/RS
The 968 TS must have used a different coolant tank. The stock tanks outlet interferes with the j boot going from the barn door to the turbo intake. I am trying to get to Pocono this coming weekend and that is an obstacle. I ran stock tank and hoses not mounted up to fill and bleed the oversized radiator. This way I could run the car up to temp and play around with fuel pressure settings. The car was pig rich. The fuel pressure regulator was set at 70psi. I now am running 3.5bar and car starts and idles.
Monday-Exhaust
Tuesday- Cyntex for Dyno tuning.
Friday- Pocono Hopefully.
Did the chassis setup last thursday and setup came out great. My biggest worry was the frame being tweeked. Thank goodness it's ok
