08-09-2024, 06:32 PM
I started a thread a few months ago in the diagnosis forum about a problem I was having with weird chattering in the engine area at low RPM acceleration. My guess (now hope) is that it was the DMF failing but I found out there are hardly any replacements available anymore and they run about $2500! I didn't want to run the super-lightweight 13lb aluminum one but luckily I found an alternative in the Spec 86S steel single-mass flywheel and ordered one for somewhere around $500.
I'm only partway through the installation but I figured I'd share what I've learned so far. Before I ordered I called Spec to confirm it should work with the original clutch, etc. and they were very nice and helpful: bottom line was that it should be a direct swap. The flywheel arrived in just a week or so and it looks very well made. It weighs in at 26 pounds (I think the old one was 32?) and I mated the pressure plate to it to be sure the bolts line up, which they do. It also comes with a nice smooth pilot bearing already inset, plus the 9 flywheel bolts you need (which saves like $50 so that was nice!)
A quick note on the bolts: the originals are longer by 2cm or so and use the wacky "three square" pattern. The replacements use an 8mm allen head which seems to have a deeper recess so hopefully fewer problems with stripping (though luckily I didn't have any issue getting the original flywheel off.)
With the old and new flywheels sitting side by side on a flat surface I noticed the new one was just a tiny bit taller. I put them on my table saw's cast iron top and rigged up a dial gauge to confirm. This measuring setup isn't very precise but it shows that the friction surface on the SP86S is 2-3mm further from where it mates to the engine than on the original. Same results for the recessed surface around the friction area where the pressure plate mates to the flywheel.
I'm hoping this won't cause any issue. I figure the effect will be that the throwout bearing rests 2-3mm further towards the back of the car, but still well within its normal travel range. My guess is this will move the clutch activation area a bit higher/earlier when pressing the clutch pedal, but maybe I have this backwards or the hydraulics will adjust in a way that it doesn't affect anything.
I'll find out soon! As of right now I have the new flywheel installed and torqued down with no issues. The rest of the re-assembly I've done several times already so if there are no surprises I'll be testing later today or tomorrow.
