09-20-2006, 12:13 AM
Hello All. I am a new member, that is now desperate for any suggestions or help. Some quick background: (Sorry if this is a little wordy, but I need someone to feel sorry for me :-(
Actually, I am going into detail just to see if anyone sees a pattern that I may be missing...
The back story
3 weeks ago, I finally purchased a 93' 968 Coupe I have had my eye on for 2 years. The previous owner finally gave in to selling it to me. In the 3 weeks I have owned it, it has been in the shop for almost 1.5 weeks.
Repairs #1
Replaced broken Power Steering tensioner.
Had the timing belt re-tensioned.
Once the above work was done, I started the car and noticed a fairly loud ticking at low RPMs. I had the mechanic at the shop listed before I drove away, and he said it was just the lifters, and that it should go away once the oil made its way up. (The car had sat for almost a week). Sure enough, he was right, the sound was gone before I hit the first traffic light.
Then the sound came back 2 days later. While going over the sound with the previous owner, we noticed rubber dust under the hood. A belt had slipped a cog and was rubbing. Back I went to the shop and they said the mechanic must had missed a cog, and that they would fix it straight away. Then the real trouble started.
The mechanic called me over to point out that the problem was not the fault of the mechanic, but the fact that 2 bolts had sheared off the A/C Compressor. The compressor was flopping all over.
Repairs #2
Drilled out sheered off bolts. replaced Compressor, etc.
Another repair bill, and they fixed that problem. (Not sure how that one got missed in the
insurance inspection...)
Then I drove home, only to have the tick return from the lifters, But this time it was not going away. I took it back again, and the shop recommended a engine flush and oil change. I drove the car 2 more days realizing that the oil pressure was getting less and less. (I have not yet had the oil changed as the oil was only done about 3000 miles ago. I figure waiting a few more days or at most 100 miles would be OK.)
Now there is no oil pressure. I took it back this evening and the mechanic is stumped. He is going to investigate further for me. The oil level is fine. It was down about 1/2 a litre, so I topped it off, but it made no difference.
SO. This sounds a bit like the Oil Pickup Tube being cracked. I have plenty of oil, and the pressure kind of comes in spurts. It used to work if I was accelerating or cornering. But now no more.
This all has been within the span of about 200 miles of normal daily driving. Now the car is parked in my garage, completely un-driveable...3 weeks after I bought it.
Any ideas??
The back story
Repairs #1
Repairs #2
Any ideas??
93' 968 Coupe, Amazon Green, Air Box Mod
