sound system dyn-o-mite ! - Printable Version
+---- Thread: sound system dyn-o-mite ! (/sound-system-dyn-o-mite.html)
sound system dyn-o-mite ! - ds968 - 10-17-2009
Part of this story is on the "sound system upgrade" thread, but it was suggested I start a new one so here it is :
A few weekends ago I drove down to SoCal with a 24 lbs , 9 sheet box of Dynamat Extreme ( Amazon.com has it available from various sources for around $ 140 to $ 160.. which is by far the cheapest price I could find anywhere ), and while there, Flash, the man whose generosity never seems to have boundries spent the better part of his Friday slicing and piercing his fingers, straining his back muscles, to install the sheets inside my doors, in the rear speaker spaces where he also shot foam and further insulated the area with some filler
( pretty sure it's asbesthos he removed from his attic, but we'll leave that alone for now for a few years until I experience pulmonary symptoms [img]style_emoticons/<#EMO_DIR#>/tongue.gif[/img] ).
And I did contribute a bit by placing sheets in the trunk area and the side cubbies spaces, but that was the easy work.. BTW, we used 7 out of the 9 sheets and covered most everything that could be covered with it..
It is important to note, nothing was changed - same factory speakers, same head unit I had put in ( Blaunkput Heidelberg ), same factory amp, etc.. And now I will say this much: WOW !!
The difference in the sound quality and power coming directly inside the cabin, as opposed to being difused while bouncing off and around every hollow space and off the body's sheet metal, is friggin' amazing. Not only can I now play everything at half the volume level as I had previously done to get the same result, but I hear every note, every nuance of the tunes.. just as they were intended to be reproduced - I'm driving with a concert hall inside my car ! Can't say enough about the difference this made. Worth every penny !
Here are some photos of the work in progress and the finished rear area..
sound system dyn-o-mite ! - Johannvb - 10-17-2009
Thanks for posting these. Interestingly your trunk dynamat, the strip in front of the spare wheel well, is in the same place as my options sticker is. Are US car's sticker in a different spot?
sound system dyn-o-mite ! - Kim - 10-17-2009
Take some comfort - asbestos is present in attics normally only in vermiculite, and that is too powdery to put in your car. However, the dynamat foam might have PCBs !!!
sound system dyn-o-mite ! - PorscheDude - 10-17-2009
Great post.
In hindsight, I should have done this when I upgraded.
<!--quoteo(post=82021:date=Oct 17 2009, 11:27 AM:name=Johannvb)-->QUOTE (Johannvb @ Oct 17 2009, 11:27 AM) <{POST_SNAPBACK}><!--quotec-->Thanks for posting these. Interestingly your trunk dynamat, the strip in from of the spare wheel well, is in the same place as my options sticker is. Are US car's sticker in a different spot?<!--QuoteEnd--><!--QuoteEEnd-->
Never paid attention to where the options sticker is on US cars, but I did not cover any sticker ( or even a spot which looked as if it had a sticker at one time ) with the dynamat. I think our stickers are up against the very rear panel .. the one below the spoiler [img]style_emoticons/<#EMO_DIR#>/blink.gif[/img] ?
<!--quoteo(post=82023:date=Oct 17 2009, 01:21 PM:name=Kim)-->QUOTE (Kim @ Oct 17 2009, 01:21 PM) <{POST_SNAPBACK}><!--quotec-->Take some comfort - asbestos is present in attics normally only in vermiculite, and that is too powdery to put in your car. However, the dynamat foam might have PCBs !!!<!--QuoteEnd--><!--QuoteEEnd-->
If it's made in China, at the very least it will have lead in it - hey, maybe that's why it's so heavy [img]style_emoticons/<#EMO_DIR#>/wink.gif[/img]
sound system dyn-o-mite ! - flash - 10-17-2009
dan - very happy it worked out so well - thanks for putting up the pics
lol - no asbestos used - it was holofill, just like it says in the DIY for the speaker enclosure
on dan's car, the option sticker is on the rear horizontal member, just behind the snapped area of carpet
<!--quoteo(post=82030:date=Oct 17 2009, 03:05 PM:name=flash)-->QUOTE (flash @ Oct 17 2009, 03:05 PM) <{POST_SNAPBACK}><!--quotec-->on dan's car, the option sticker is on the rear horizontal member..<!--QuoteEnd--><!--QuoteEEnd-->
hey, just to set things clear, my "horizontal member" does not have stickers on it [img]style_emoticons/<#EMO_DIR#>/dry.gif[/img] [img]style_emoticons/<#EMO_DIR#>/tongue.gif[/img]
