Clunk when braking-Right rear (or is it a thunk?) - Printable Version
+---- Thread: Clunk when braking-Right rear (or is it a thunk?) (/clunk-when-braking-right-rear-or-is-it-a-thunk.html)
Clunk when braking-Right rear (or is it a thunk?) - anthonymaher - 07-29-2010
Hi all;
Bought my 94 coupe with M030 and LSD with about 66k on it about 2 weeks ago. I have been working my way through repairs on what seems to be the common failures and easy upgrades for the 964:
-Odometer gear (unplugged the airbag to do this and now the warning light is on all the time---@*&!!$#!!--should have read about it in the forum first)
-Sunroof hinge
-Standard tune up--plugs, rotor, etc
-Airbox mod
Belts and water pump are next along with an inspection of the variocam chain and pad
So, one question and one comment:
The question: There is a distinct clunk when I brake--the sound comes from the right rear, generally at the rear seat footwell. It feels like some linkage gone bad. It is not a vibration, or causes the wheel to shake. Thoughts or comments? I will be looking at it this weekend, but getting me pointed in the right direction would be much appreciated.
The comment: I feel like I have gotten a whole lot of car for the money; Im not sure what other automobile with this level of performance I could have purchased at this price. Wow. [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
Clunk when braking-Right rear (or is it a thunk?) - rxter - 07-29-2010
Could be as simple as something clanging around in the RR compartment under the hatch carpet. Could be as ugly as a bad ball joint.
Clunk when braking-Right rear (or is it a thunk?) - Ryan - 07-29-2010
Sounds like it could be bushing related. There are a few rubber bushing in the rear suspension as you probably know. Could be time for a rebush.
That being said, I had a similar clunk sound from the rear of my 944 that I could not find and it went away after a while. Go figure.
Enjoy the car!
Clunk when braking-Right rear (or is it a thunk?) - flash - 07-29-2010
there are a lot of things that can cause a clunk like that - eliminating the obvious of things in the back of the car, my first thoughts are:
loose caliper
broken brake pad
loose or worn CV joint
worn control arm bushing
worn shock bushing
