Noise when I start the Engine - Printable Version
+---- Thread: Noise when I start the Engine (/noise-when-i-start-the-engine.html)
Noise when I start the Engine - williamoss - 11-26-2015
When I start my engine there is a squeaking sound that last only for a few seconds. Then it goes away. it sounds like a pulley binding sound. Any Ideas?
Noise when I start the Engine - Bulti - 11-26-2015
Probably just a belt that you need to tighten. A/C - alternator belt or power steering belt.
Noise when I start the Engine - ds968 - 11-26-2015
+ 1 on Philippe's post. Just to test the theory, use some belt spray ( one belt at a time so you know which one makes noise ) and if the squeal stops when you start the car, that belt probably needs tightening .
Noise when I start the Engine - MCL968 - 11-27-2015
Usually that's when the alternator is replacing the energy used by the starting process. Turn on the headlights and see if it prolongs the squeak. If it does, it's the alternator belt.
