Need to replace my shifter bushing(s) - Printable Version
+---- Thread: Need to replace my shifter bushing(s) (/need-to-replace-my-shifter-bushing-s.html)
Need to replace my shifter bushing(s) - SoCalKen - 05-10-2005
Need to replace my shifter bushings, have the bottom cup and the 2 side bushings. Is there a link to a description to how to replace these?
Ken
Need to replace my shifter bushing(s) - flash - 05-10-2005
come on over - we can knock it out in a hurry here
Need to replace my shifter bushing(s) - Anchorman - 05-10-2005
I've done this, but a search didn't turn up the info. It's really quite a simple and straightforward job - just doing the logical dismantling gets you where you need to be. What I found the most difficult part was looking at the car when the console and shifter were out - I found that disconcerting. Here's the only photo I have.
the trickiest part is installing the new lower bushing without cracking it - i broke 2 of them until i figured out the trick - you can't bang on it without that risk - a very heavy grease does a good job of helping things along
then of course you have to adjust it correctly at the 85 degree angle when finished
just give me a call - we can handle this very quickly over here - besides, if you break the lower bushing, you'll be stranded - fortunately i have a couple of extras
Yes, getting that lower bushing on was a little nerveracking - and I didn't have either a spare bushing or another form of transportation. Placing the shift rod squarely on the bushing and rapping sharply with a small sledge hammer did the trick.
did that first time too - shattered the bushing - then i placed the base on something soft - did it again - after adding the grease, i could just push it down and it was home - third time was charm
Need to replace my shifter bushing(s) - SoCalKen - 05-11-2005
ok....
Anchorman's picture scared me, I'll give you a call Flash...
Thanks!
<img src="/forum/images/smilies/968/blink.gif" class="smilie" alt="" />
Need to replace my shifter bushing(s) - Anchorman - 05-11-2005
SoCalKen - as I'd said, it scared me, too. But - it looks MUCH worse than it is. You can do it, but if you're going to get Flash's assistance, I'm sure it will be uneventful. It's really a much simpler job than it appears to be.
Need to replace my shifter bushing(s) - mitch968 - 05-11-2005
I replaced the cup bushing about a year ago. I had ordered an extra in case I cracked one, but didn't need it. I put the lever and bushing on top of my wooden workbench surface, used a little grease, and smacked it with a rubber mallet until it went in. I think as long as you don't use excessive force, it should be ok. Then again maybe I just got lucky.
Need to replace my shifter bushing(s) - Vedder - 05-12-2005
I did mine as well a couple of weeks ago, really nothing to it, just took all things around it to work with more clearence, like console, shift, etc.., as for the install, i just put heavy grease on it, then aplly constant pressure on the bushing, dont bang on the shift its really soft metal, and assemble it outside the car.
Need to replace my shifter bushing(s) - BigL2U - 11-23-2005
I'm replacing my shifter and stick with an after market one. When I removed the old stick and rubber boot I can see the plastic insert in the shifter bearing bracket is broken (cracked). Is this what you are referring to as the bushing?
I called a couple of Porsche dealers and they don't have the part in stock but can order the shifter bearing bracket (w/screws) and have it expressed mailed to me by Monday.
I thought about gluing and re-using the original "bushing" but express mailing the whole assembly only cost $37 total. Do you guys have any recommendation or suggestions?
Need to replace my shifter bushing(s) - Dave - 11-23-2005
Take a good look at the lever pin that protrudes through the shift rod while you're in there. If they are like the 944 unit, they wear and place strain on the circlip holding the shift rod onto the lever.
Then, the bloody thing just pops out and falls into a hole while you're driving home from the airport on a Friday, wearing a nice suit and tie, and fishing for any gears at all.
Ask me how I know <img src="/forum/images/smilies/968/wink.gif" class="smilie" alt="" />
Need to replace my shifter bushing(s) - Anchorman - 11-23-2005
The bushing that's discussed is a plastic cup-like piece that the ball at the bottom end of the shift lever sits in. There are also plastic sleeve "bearings" on the extension bars of the lever that should be changed at the same time.
Need to replace my shifter bushing(s) - apex - 11-23-2005
I once compiled a list of parts for shifter maintenance - but PET won't work on my computer anymore... could someone verify that this would be the list? I think included here are the cup-bearings along the control linkage to the tranny. If someone could vet this then I'll order the whole package. Maybe the parts list can help others, too.
1 944.424.139.01 06 - bellows
3 944 424 231 01 12 - bearing shell (bushing) order three - you’ll break one
1 944.424.139.01 17 - lock for lever
1 N 027 381 2 18 - fit washer for lever lock
2 999 924 002 40 19 - bushing for lever lock
1 999 222 015 01 20 - concave washer for lever
1 944 424 015 02 lever
Need to replace my shifter bushing(s) - BigL2U - 11-29-2005
Thanks for the insight..
Apex your "shifter maintenance parts list" is very helpful.. I think I've got some more inspecting to do..
Need to replace my shifter bushing(s) - kwikt - 10-30-2010
Reviving an old topic. Where did you guys get your bushings?
Need to replace my shifter bushing(s) - flash - 10-30-2010
i got mine from sunset
Need to replace my shifter bushing(s) - Cloud9...68 - 10-30-2010
What are the symptoms of worn shifter bushings? Is it just something that should be done after a certain number of miles, or are there specific symptoms that trigger the need to replace the bushings? Thanks.
Need to replace my shifter bushing(s) - kwikt - 10-31-2010
Reason I'm asking is because my son called yesterday(180 miles away with the car) and said the shifter suddenly became very loose and vague. He said that the shifter throw is longer and seemed to have moved to the rear of the car. 1st, 3rd and 5th seem ok but 2nd, 4th and 6th seem to bottom out before engaging. I am ordering the cup bushings thinking this is the problem without physically looking at it.
Need to replace my shifter bushing(s) - kwikt - 11-03-2010
Took the 180 mile trip today and fixed once again. Surprisingly it was the circlip on the rear pivot linkage slipped out of the groove. The kid must have been banging gears.Simple fix but very tight area to work in.
