Body Trim -
MattS - 01-06-2006
On any of the 968s I have looked at the black trim/gasket/seal for the body panels like the bumpers and sideskirts, the balck trim has shrunk up and is now too short or is pulled out at the corners.
What is the fix for this?
Can you get the parts?
Do you need to remove all the affected panels and put new trim in, etc.
Body Trim -
flash - 01-06-2006
it's an easy and inexpensive fix - you replace them - call sunset imports
you do need to pull the "affected" panels, but they are only the bumper covers and rocker panels, which all easily unbolt/unclip - you can do the entire job in a half day
total expense is around 100 bucks
Body Trim -
MattS - 01-06-2006
Cool, thanks Flash
That is kind of what I thought but I wonder why so many have not fixed it.
[quote name='flash' date='Jan 6 2006, 12:39 PM']it's an easy and inexpensive fix - you replace them - call sunset imports
[right][post="14268"]<{POST_SNAPBACK}>[/post][/right][/quote]
Body Trim -
flash - 01-06-2006
it probably scares people - it seems like a big job, until you've done it once - there are a couple of tricks that can make it a lot easier - i did a write up on the bumper cover removal, but i can't remember where i posted it
