sticky clutch on my new ride - Printable Version
+---- Forum: Clutch & Flywheel (https://968forums.com/forum/clutch-flywheel)
+---- Thread: sticky clutch on my new ride (/sticky-clutch-on-my-new-ride.html)
sticky clutch on my new ride - ether_joe - 02-08-2006
hey guys, I got my '92 coupe a few days ago and I am in total bliss!
On the maintenance side, I have the 'sticky clutch' problem -- the clutch does not return back up 100% but sticks at the beginning of the free play of the pedal. It sounds exactly like the thread below
http://65.61.16.109/forum/topic.asp?TOPIC_ID=11115
according to records provided with the vehicle, slave cylinder was replaced in 2001 and master cylinder in 2004. Maybe the slave needs to be replaced again?
Is it dangerous to drive the car like this? Didn't think so, but I am going to check the hoses tonight and perhaps order up some replacement parts.
How much time would be saved if I bought one of those Motive power bleeders? I have to do the brakes too so I just might get one.
sticky clutch on my new ride - Greimann - 02-08-2006
Yes on the Motive. Anyone who has used it will say, "Once you go pressure bleed, you'll never go "presser" bleed." <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
So get it bled well first, then if it still sticks, try adjusting the push rod a little longer or dial back the preload on the booster spring.
There is no danger in driving this way. It is just annoying,
[quote name='Greimann' date='Feb 8 2006, 04:18 PM']Yes on the Motive. Anyone who has used it  will say, "Once you go pressure bleed, you'll never go "presser" bleed."  <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
[right][post="15715"]<{POST_SNAPBACK}>[/post][/right][/quote]
thanks, I really appreciate the advice. It sure *is* annoying.
Just purchased a power bleeder. New brake pads and clutch work will be pending delivery, now that I know I won't kill myself. <img src="/forum/images/smilies/968/rolleyes.gif" class="smilie" alt="" />
sticky clutch on my new ride - josephsc - 02-08-2006
Congrats, Joe!
I'm also in the East Bay. Well... to be precise, my stuff is in East Bay these days while I could be anywhere among SF, LA, NY and Boston at any given time. But if you ever need anything -- say in terms of tools or a lending hand, give me a hollar!
Joe
[quote name='josephsc' date='Feb 8 2006, 04:54 PM']Congrats, Joe!
Joe
[right][post="15720"]<{POST_SNAPBACK}>[/post][/right][/quote]
Josephsc hello, I have been enjoying your Avatar for quite a while. <img src="/forum/images/smilies/968/laugh.gif" class="smilie" alt="" />
Yep, let's definitely get together, I am looking forward to meeting the local 968 crowd and I've also been reaching out to the 928'ers, they're a lot of fun also.
I'l shoot you a PM.
sticky clutch on my new ride - ether_joe - 02-09-2006
okay, the brake pads provided by the PO -- he was going to do the brakes and drove the car only 400 mi in two years -- they don't look like anything special.
I am wondering if I should buy some better pads?
They are the same ones I helped my friend put on his BMW 325, 'PBR' brand "Deluxe Plus Organic' (WTF? No preservatives?) They do mention 'sporty roads requiring aggressive braking'.
How important is a top-of-the-line brake pad?
sticky clutch on my new ride - Mark - 02-09-2006
Poor man's bleeder link
sticky clutch on my new ride - 94SilverCab - 02-09-2006
The trouble may have a simple answer.
On SEVERAL of the cars that Pete at RS Barn has seen recently (including mine) the inspection port plug for the clutch fork was missing and the area needed to be lubricated with silicon spray and the plug replaced (about $7).
Mine had been missing for a while and Pete lubricated the area several times before it returned to 100%.
Regards,
