Problems with Porsche-alarm after chip change - Printable Version
+---- Thread: Problems with Porsche-alarm after chip change (/problems-with-porsche-alarm-after-chip-change.html)
Problems with Porsche-alarm after chip change - mattipuh - 04-22-2008
We changed the Motronic chip few weeks ago with a friend. Otherwise everything went ok, but after the chip update I have had occasional problems with Porsche alarm system
1. sometimes the wireless central locking / alarm is not working, it is impossible to open doors from car wireless, and it is impossible to switch off the alarm.
-> antenna for remote key in alarm box is not proprely placed (wireless connection problems?)
2. Sometimes doors lock even though I have not pressed the remote locking button
-> is the alarm box loose, or some wires in it, which makes it function by itself?
maybe the assembling of the boxes after chip install has not been good enough, i most likely will open the box assembly again around the motronic, and see that everything is well and firmly assembled. Would there be any special things I should take care of when assembling the boxes / alarm back to its place, to make it function properly again? How should the antenna be placed, etc?
What would be the screw specs which assemble the frame and/or boxes? we lost couple fo screws during unmounting (amateurs working, yes <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />, and It would be convenient to purchase extra screws before disassembling, so I could fix all screws which are missing, to make sure that everything is well assembled
Thanks for the insights!
Br.,
Matti
P.S. 2 weeks for the LWFW-install... more acceleration thrill anticipated.. <img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" />
Problems with Porsche-alarm after chip change - banditsc - 04-22-2008
As far as I knew Porsche never had a wireless alarm system for the 968's. Many have added on aftermarket alarms and keyless systems as a add onto the factory alarm though.
Check all the wire connections, since it's most likely aftermarket it's possible there are some shakey connections in there.
Apologies, I have to be more spesific. The Car has porsche alarm, which is activated from the wireless central locking. the central locking (and also alarm with it) keeps acting funnily.
Problems with Porsche-alarm after chip change - flash - 04-22-2008
wireless central locking?
