Passenger side fluid leak - Printable Version
+---- Forum: Heating, & Cooling Systems (
https://968forums.com/forum/heating-cooling-systems)
+---- Thread: Passenger side fluid leak (
/passenger-side-fluid-leak.html)
caffine - 09-16-2008
Thanks to Pete at RSB for pointing me in the right direction for my fluid leak. While ordering the RSB stage 1 chip we got to talking and Pete provided lots of helpful information. <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
Quickly found the source of the power steering leak - a hose was improperly clamped when the recent Power steering resorver was installed by the last owners mechanic. The hose had a cut in it an inch or more down from the end.
Now I just need to replace the hose (the one with the rubber hose connected to a long metal tubing going underneath the wheel well. )
Can the rubber hose section be replaced by itself or does the entire assembly (rubber/metal) require replacement?
banditsc - 09-16-2008
I brought that line with the PS fluid cooler attached to a hydraulic shop and had them replace just the rubber part. It cost me about $25. I have heard of other just cutting the rubber hose off replacing it with a new hose and hose clamp with good results.
Thanks - will experiment with a hose and clamp.
- Bill
If you go that route, just cut away the crimped band, underneath it should be a kind of flanged line that the rubber hose will fit over.
caffine - 09-17-2008
[quote name='banditsc' post='59977' date='Sep 16 2008, 09:04 PM']If you go that route, just cut away the crimped band, underneath it should be a kind of flanged line that the rubber hose will fit over.[/quote]
Thanks. Will do. Got the hose & clamps from autozone today. The autozone guy suggested I double clamp the hose at the flanged line end you are talking about. May have to wait till tomorrow as my son's HighSchool has homecoming activities tonight.
This forum is awesome with everyone helping one another! <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
