poly bushings
is there a source for front sway bar poly bushings?
Specifically where the sway bar mounts to the frame.....
[quote name='xrad' post='50325' date='Apr 3 2008, 07:24 PM']is there a source for front sway bar poly bushings?
Specifically where the sway bar mounts to the frame.....[/quote]
Try RS Barn.
The front sway bar mounts to the drop links in the center and to the aluminum controll arms on the ends.
I have/sell Delran poly bushings for the center drop links. They work great. I also advise the sway bar support braces.
I am not a fan of solid bushings on the sway bar ends.
Pete
I went through the RSBarn site and did not see them....
Pics/price? Link?
Call.
Thanks!
see RS Barn / suspension / Racers Edge / and scroll down
1994 cab : slate gray & bordeaux top + 6 sp. man. + LSD 220 + OEM 17" cup I + stock airbox mod + K&N + RS Barn header + free flow cat + RSB st 2 chip + KW-V3 + M030 sway bars with delrin and KLA + up and lower brace + SS clutch line + rack tack + Stuttgart Shift block
Sorry,
There are lots of things available but not posted very well on my web site.
I could spend lots of time on the site or continue fixing cars and developing products.
Please call
Pete
06-25-2022, 04:42 AM
