Threads: 12
What pad and rotor combination are the F-stock guru's running? And do you run the same combination for street applications?
I have the standard brake calipers and rotors on the car. From reading the F-stock rules it sounds like rotors and pads are free but not calipers?
I am sure I finished off the front pads and rotors from my track outing last weekend. Hallett is rough on brakes. Going to check in a bit.
Bart
'92 968 Arrest me red Coupe
'71 G-Production 510 #61
Threads: 5
Everyone in F uses full race pads that you wouldn't want to run on the street. I use Pagid Blacks or Hawk Ht-10's. Others use Pagid Orange, Hawk Blue, Performance Friction 97's, etc. All of these work great on the track, but are too dusty and noisy for street use, plus they work poorly at street tempertatures.
You have to use 968 calipers otherwise you get bumped out of F Stock into E Prepared. However, since the M030 calipers were optional on the car, you can replace the standard calipers with the M030 calipers. All of the fast 968's that I'm aware of are running the M030 front calipers.
Opinions vary on rotors. My view is that rotors are disposable, and that any extra money spent on a set of rotors is better spent on the next set of rotors. I use non-drilled, non-slotted Zimmerman rotors at $95 apiece. Others spend extra money on drilled, or slotted rotors. Some get their rotors frozen. Others even use the Porsche factory cast-hole M030 rotors at $300 apiece <img src="/forum/images/smilies/968/ohmy.gif" class="smilie" alt="" /> I've tried all of the above, and none worked any better or lasted any longer than the cheap, simple Zimmermans, so that's what I use.
Jim Child
'94 968 PCA E-Stock/NASA GTS2
'01 Boxster
Threads: 12
That is what I figured but thought I would ask. I run Hawk Blues on the 510 and they work great but wouldn't use them on the street.
What would you recommend for street pads? Dust doens't bother me too much but don't want a noisy set up.
When upgrading to MO30 calipers do you have to also convert to the MO30 struts or can you add aftermarket threaded collars? I would assume it is difficult to find the MO30 strut assemblies??
Thanks!!
Bart
(This post was last modified: 04-30-2005, 03:39 PM by
Bart.)
Threads: 5
[quote name='Bart' date='Apr 30 2005, 06:35 PM']What would you recommend for street pads? Dust doens't bother me too much but don't want a noisy set up.
Thanks!!
[right][post="3997"]<{POST_SNAPBACK}>[/post][/right][/quote]
I like Metal Master pads for street use.
You can upgrade to the M030 calipers without upgrading the struts. Shocks and struts are free in the PCA stock classes, so you can do anything you want there. The fast 968 racers I know are running Ledas or Motons.
Jim Child
'01 Boxster
Threads: 3
[quote name='Bart' date='Apr 30 2005, 02:35 PM']That is what I figured but thought I would ask. I run Hawk Blues on the 510 and they work great but wouldn't use them on the street.
Thanks!!
I only do Auto-X, and street drive my pad choice is the Carbotech Panthers, a
little dust but easy to take car of. Have also used the Metal masters IMO not as good as the Carbotech Bobcat, which is a great street pad, no dust and excellent cold stopping power. just my .02 worth
thanks Rob F
1994 968 coupe polar silver 200K "greyghost"
2004 Boxster S 550 SE "box"
1993 Miata le "blackie"
2002 Yukon xl 4x4 502ci "Kong"
