Outside temp display (also posted to Rennlist forums)
I removed my outside temp display to replace the light bulb. Prior to replacing the bulb, the display worked properly. After replacing the bulb and reconnecting the wiring, the display shows -36 degrees F (I'm in CA- it was in the 60's today) for a couple seconds after turning on the ignition key, then goes blank.
There are two 15 amp fuses (#11 and #36) labeled "exterior temperature display"; both fuses are ok.
Any solutions? Thanks in advance.
Joe
Joe
1995 968 Coupe
Guards Red/Black
When you replaced the bulb, did you have to do any soldering to make the bulb work? I did, supposedly the exact replacement isn't available any more so I had to solder a smaller one in.
If you soldered it in, wouldn't have been hard to drop a piece of solder where it shouldn't have been...
Take it apart and use and ohm meter to make sure all is okay...
Michael Sorbera
aka San Antonio Silver Bullet
2002 VW Beetle TDI
2004 Nissan Titan Crew Cab
1990 Mercury Grand Marquis
No soldering was necessary. Quarter-turn counterclockwise to remove the old bulb, quarter-turn clockwise to install the new bulb.
Does anyone have a procedure for diagnosing operation of the display?
Thanks.
Joe
Joe
1995 968 Coupe
Guards Red/Black
Last Post by hot968
08-03-2022, 08:25 PM
Last Post by Speedster
04-05-2021, 08:03 PM
04-18-2008, 02:17 PM
