03-27-2007, 10:06 AM
What do you guys do re our cars propensity for spinning rod bearings? I gather that dry sumping is still the exception rather than the norm so what are we all doing to avoid engine rebuilds? I know that there are sump baffles, crank scrapers, crank mods, accusumps etc. Who is using what method and how many of us have had to rebuild the engine due to oil starvation? Also I believe that the 968 has oil piston squirters? Am I right? Why can't we have some sort of oil squirter at the crank or bearings so that on those long sweeping left turns when the oil is in the next suburb, we at least have some source of constant oil being sent to the affected areas?
Maybe it's a dumb question, but I feel dumb having to risk my engine every time I go out on the track. So dumb that I've bought a dry sump system but that won't get installed for a little while until we figure out where everything can be fitted on a road/track car while retaining p/s, a/c, and stock alternator. Need to come up with a bit of genius as to what sized and shaped oil tank and location too? Any ideas on this would be appreciated as well.
(This post was last modified: 03-27-2007, 10:13 AM by 333pg333.)
