Threads: 24
I `am thinking about renewing my stereo in my 968, at the moment there is an Pioneer (4x45watt)unit from 2002 in the car. While looking at the wires/ mounting points of the stereo I noticed that there was a round DIN plug sitting in the stereo compartment. My car came with the 490 option, so I thought this round DIN plug must be used to power the (2) amplifiers. A quick look under the seats....and yes there are 2 amplifiers. Since all the wires are still present, is it a good thing to get amplifiers working again or should I just take them out of the car? (The only thing I have to do is to modify the round DIN plug into the more modern rectangular DIN plug.....)
Regards,
Rutger
1992 Amazon green convertible. Cargraphic cat. back exhaust, RS Barn/ Design 1 Racing lower & upper strut brace, RS Barn stage 1 Chip, Airbox modification, M030 Swaybars.
Threads: 24
Flash,
My car(convertible) has 3 speakers in each front door, and in the back there are two "two in one " speakers. The speakers in the back are not OEM, but they do fit in the original housing. The "bass" speakers in the front door are replaced by more modern Pioneer units.
Regards,
Rutger
ps should I change the mid range speakers in the front doors as well?
Threads: 31
The factory amps actually are pretty clean just low powered, your Head Unit has more power.
That round plug is probably for the factory cd changer.
Threads: 13
[quote name='Mark' post='32427' date='Mar 14 2007, 02:09 PM']The factory amps actually are pretty clean just low powered, your Head Unit has more power.
That round plug is probably for the factory cd changer.[/quote]
Hi Mark that plug is probably a din connector with 8 pins.
Look at this drawing.
Under each seat you have this din connector and at the back of the original radio you have 1 din plug.
The drawing is including the pin layout.
Ritchie
Owner of '92 coupe with the m030 option.
Threads: 31
I guess since my 490 car is a '94 it's a little different or the previous owner hacked it up. <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" /> I do have the DIN at the amp but I have a standard blaupunkt connector for hooking up to the factory CR1 at the head unit end. I do have a DIN for the factory CD changer at the Head unit.
(This post was last modified: 03-14-2007, 03:15 PM by
Mark.)
Threads: 24
Richie,
Thanx for the drawing of the DIN connector. I still have one question, how should I connect the channels 1,2,3 and 4? i.e. is channel 1 front right or front left? or should I check the colours of the wires coming from teh DIN plug?
Regards,
Rutger
Threads: 13
Rutger I can not tell you, Because I think it depends of the radio you will use.
Better is to connect the channel and listen with side of the car is given a response. I had to make a new cable from the dinconnector to two tulp connectors. And tulp connectors are easy to change.
Threads: 76
I just had a new Alpine head unit installed in my car with the 490 option. The old dual amps under the seat were emitting a nasty buzz that I originally thought was the speakers. Just used the amp in the Alpine and went past the old amps. Worked like a charm. Eventually I'll get at them and remove.
Ralph
'77 911S (RIP)
Threads: 167
Last weekend after the Annapolis Fun Run Darryl offered to help with my non functioning door speakers. He removed the head unit and applied a sound tested and we discovered that the amplifier under the passenger seat was toast.
Darryl also decided it was better to work around the amp so we picked upa new Alpine unit at Best Buys.. A plus for me because I have recently purchased an iPod and wanted the direct connection anyway.
All wired up and ready to go, we couldn't get the back speakers to work. Apparently the low power goes through the amp and we couldn't make it work. Darryl is working on a bracket solution so we don't have to destroy the original speakers and it will definately be worth a drive back down to visit with Darryl and Christine and wire in some new speakers in the back that don't need seperate power. Meanwhile I have the other 6 speakers <img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" />
Hears a pic of the rear speaker box.
Regards,
Threads: 31
At least you guys got those rear speakers out, I hvae one that's dangling loose because I ran out of time while removing it. <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
Threads: 31
Darryl, any progress on the rear speaker stuff?
Threads: 69
[quote name='Mark' post='36623' date='Jun 8 2007, 08:33 AM']Darryl, any progress on the rear speaker stuff?[/quote]
Not as of yet...when Jay returned home to PA, we reinstalled his boxes so we could put his car back together. We havne't setup a return visit yet.
Didn't you say you had one hangin' out? I need to have one (or both) of these boxes for awhile to be able to test out a couple of ideas. Are yours available for guinea pig status? Of course, in return, you'd end up with new speakers in the rear. If you're around tomorrow (or any weekend for that matter), I'm usually tinkering at my office - near Dulles Toll Road and 28 in Sterling.
- Darryl
Threads: 69
[quote name='flash' post='36625' date='Jun 8 2007, 09:03 AM']i want ot borrow a set of boxes from whomever gets them out first and has them sitting around - i think i want to use them as a mold for a backshell[/quote]
Yes, basically the same idea I had...let's make a mold and be able to just drop a 4x6 in there...the wires are already there that go up to the radio. I've verified continuity on at least one pair.
(This post was last modified: 06-08-2007, 11:02 AM by
Darryl.)
Threads: 31
Sounds good guys. Yes I can definitely live without the rear driver's side since it is blown and irritating the crap out of me. <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
Daryl PM your number please, I somehow did not save it last time.
Threads: 167
Thanks Mark, save me a trip to DC until I can have a plug-n-play solution installed (THANKS DARRYL!)
Keep me in the loop on progress
