Threads: 17
Ok so I broke down and bought a new german canvas top from GAHH. Now how do I put it on? I get the feeling that most if not all you guys have had the tops put on by a upholstery shop. Anyone try to DIY this? If not then I could use a recommendation for a shop is or around Pasadena CA that I may be able to trust. If it's a little farther that's ok too. Anyone know of one?
Cheers
Steve Patrick
92 968 Cab
76 912E Coupe
68 912 Targa
68 911 Coupe
78 Alfa Spider
62 Alfa 2600 Cab
Threads: 17
unfortunately you went with a GAHH copy
??? I thought that GAHH made one of the best tops, is that not the case?
Steve Patrick
92 968 Cab
76 912E Coupe
68 912 Targa
68 911 Coupe
78 Alfa Spider
62 Alfa 2600 Cab
Threads: 18
Check out convertibletops.com they sell Robbins.
93 midnight blue cab
03 kawasaki zx6rr
03 k2500 duramax
83 944
66 volkswagon squareback
Threads: 34
Be prepared! "The Book" calls for 12+ hours labor to replace the top on a 968. Depending on the hourly rate, it can be a bunch. When I replaced my top two years ago here in Atlanta, I got quotes anywhere between $1850 and $2300 from 4 different shops, including the top. I bought an aftermarket top and found a guy to install it for only $600.00. He bitched and moaned when I picked the car up that he should have charged double!
Threads: 17
[quote name='flash' post='56125' date='Jul 10 2008, 10:37 AM']yeah - not that bad around here - total job, including top, is only about $1200 - he has his own top, so i'm guessing anywhere from $500 to $750[/quote]
With tax the top from GAHH goes for just under $900 so IF I can get it put on for $500 then its a $1400 job. I am guessing that its going to be around $1500 or so.
Steve Patrick
92 968 Cab
76 912E Coupe
68 912 Targa
68 911 Coupe
78 Alfa Spider
62 Alfa 2600 Cab
Threads: 17
The new GAHH top is is on the car and it makes the car. It is so nice to be able to see clearly out of the back window.
It is not as tight as the original or as bulky. I am going to go back and see for the guys that put in an (Arthur's in Pasadena) and see if they can snug it up a little. BTW, Arthur's charged me $550 to put the top on.
Steve Patrick
92 968 Cab
76 912E Coupe
68 912 Targa
68 911 Coupe
78 Alfa Spider
62 Alfa 2600 Cab
