New to the 968 world! ^_^
Hi there! I am a car lover and enthusiast.
I currently do not own a 968 but I plan on doing so eventually. I usually work on Nissan 240sx. I have also dabbled with drifting and became semi-decent with it.
Teach me and help me continue to crave for a Porsche!
I found one ('93 Cabriolet) for a very good price. I just want to know if it will be worth the effort to fix it back to show quality!
Needs new top, rubber seals for around the top of the windows, new odometer, belt and full interior. Besides that it runs.
I hope people on here are nice! <img src="/forum/images/smilies/968/tongue.gif" class="smilie" alt="" />
Michael
Welcome to the forum, and good luck in your search <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
It has been said that there are no "cheap Porsches", which in 968-speak means you can spend (let's say for the sake of argument) $15,000 for a great-condition car, or you can spend $10,000 up front and then $5,000 more fixing it up. At some point, if you spend say $8,000 or less, you might have to spend at least that much again, and maybe more, to get the car into great shape if it's even possible. These are of course just my opinions and the numbers are not absolute.
Depending on your region, and what condition you want your car to be in, you should be able to find a fine example of the 968 for $15,000 or less, and my advice is to spend the money on a better-condition car than on one that needs significant work in the hopes it won't add up too much.
Do bear in mind that little parts, although they don't appear to look like much, can be hard to find (no longer available) and their price can be "significant". Parts are even more expensive depending on what side of the car they're on in some cases. Fog lights, timing belt covers, flex dampeners, cab top bows, little rubber pieces on the cab top - all examples of low supply leading to very high costs if you can even get the parts.
As a way of helping estimate costs, I just had the top done on my '93 cab and it cost about $1,700 parts and labor. I had the belts and rollers done (you'll have to do that too) and a bunch of other work that just needed to be done (motor mounts, coolant hoses, front seals) and that was about $2,700. I don't know the extent of the interior replacement you need to do, but someone else on the forum can help with that.
I hope that helps - and again, good luck in your search. You can find a great-condition 968, but you might have to look at a few rats first.
Welcome, I agree with Tama as a relatively new owner. I bought a mint car. Yet things do happen, broken sunroof $1100. When you buy an almost 20 year old car be prepared for unexpected expenses. On the flip side, they are a blast to drive and just a lot of fun. Do your due diligence and don't jump at just anything. I passed on a cab 2 years ago that surely had problems and ended up purchasing my current. The ole patience is a virtue bit. Enjoy
Welcome! If you want a "show quality" car, they can be pricey garage queens. My 968 is a "driver", good shape but not a concours car and that's fine with me. Enjoy the hunt and have fun!
Jim
Jim
"Top down weather is anytime it ain't rainin'....assuming the heater works."
Hello and welcome.
Thanks for the great responses! Basically I found one for $6k and need to know if the rapair costs would make it worth it or should I just go for a $12k one?
The issues:
needs new top
belts worn (squealing...)
odometer broken (says 64k but has ~154k)
interior a little rough (I don't mind slowly replacing interior parts)
The seals for the windows to top are all messed up, how much to get this replaced?
Besides that it is a pretty straight forward Porsche.
My main concern is the seals around the windows to the top. I have no idea where to locate new ones..
Thanks!
Michael
Is there a good website for someone or a company that sells misc. parts for the 968?
tough call - you would really need to carefully inspect the car
every original rubber component in the car is well past its life expectancy - that can add up - carefully inspect every bushing - assume all hoses need to be changed, especially the hydraulic ones, since you normally cannot see damage or wear from the outside, as they fail from the inside out
check out the PPI form in the Buyer's Guide area - it will give you a good check list
assume that without records, any car needs at least belts (3 year max life, no matter how few miles)
check out the frame and motors and not just the canvas - that can get pricey
at 154k, assume you need variocam, head gasket, and possibly a valve job
at this age, it gets close as to which direction is best
i'd lay it out on a spreadsheet - then i'd lay myself out on a lounge chair with a glass of wine and really think about it
It's always tough when you're searching and have an example of the car in front of you - the urge is to buy and fix what ails it later.
There are a collection of web sites where many (but not all) parts can be located. I generally flip back and forth between Automotion.com (a better search feature) and PelicanParts.com (better prices), with jaunts to Vertex Auto, Paragon, and a few others for less widely-available items.
Thanks for the replies!
It looks like I will no longer be pursuing the cheap 968. There were WAY too many issues with it!
I did though find a really nice 1993 with under 90k and has all maintenance papers. It looks CLEAN! Perfect everything!
Welcome, Sounds like a better prospect than the first.
Last Post by stv951
04-30-2026, 04:02 PM
Last Post by Mike4749
04-23-2026, 05:35 AM
04-20-2026, 08:27 AM
04-18-2026, 09:57 AM
08-28-2025, 07:02 AM
