ok - no - not the 2nd car - this is a complete re-do of the 1st car
not using a mid at all - cabin not designed well for mids - i'd delete them if i had them - not a fan of 3-way systems anyway (as is the case with most audio engineers i know) - too messy to tune without going to separate amps for each speaker and using variable crossovers
this was one where you had to spend money to get it right - the cheapie stuff just doesn't work well enough to get everything i wanted out of it - i fought it for a long time, but finally caved in to more amps and better speakers - the other stuff was "OK", but never really good enough at 80mph with the top down
the 5.25" got a pair of kenwood 5.25" woofers from a 2-way separate set - the enclosures got sealed - while the spec is much lower, they are good down to about 50, though i am cutting them off at 63 with a 6db/oct slope
i am using the crossover that came with the kenwoods and using factory tweeters up front
the boxed enclosures in the rear from the 490 upgrade got torn apart, lined with dynamat extreme, the internal amp discarded, and used the factory 4" woofer and 1" tweeter - they go down to about 60, but i am cutting those off at 100hz with a 6db/oct slope - very nice now, but may play with tweeter caps some more - listening to it by itself, i have a hole in the upper mids in the rear that i think i can fill a bit better with a different cap in the first order crossover - the 4 ohm 4" doesn't really go high enough, and i have the 8 ohm tweeter cut off too high - i did it on purpose though, so as not to have a bunch of 3.1k screaming in my ear, but i may have gone a touch too far - not sure yet - when in conjunction with everything else, it works very well
the woofers were a real improvement - the 8" Punch 1s were not enough - they only went down to 50hz - neither was the 65/ch amp driving them - now i am running 200/ch at .05 THD into a pair of 4 ohm single coil JL Audio 8" drivers that go a LOT lower - MUCH better - really bumps now
the new 4 channel amp arrives tomorrow so that i can take the 4 channels off of the deck and onto the amp, tripling the power output - the 50 w/ch peak (22 RMS) just was not nearly enough to drive any bottom out of the 5.25"
the secret to all of this though was the tuning - the EQ and the time alignment really made the system work
