so, dan finally decides to go ahead and upgrade his suspension - doing the normal stuff - konis up front coilovers all around - M030 bars - yada yada
in keeping with dan's desire to maintain a comfortable ride, we chose very reasonable spring rates front and rear, shocks that would be easily adjusted, and even stuck with the rubber sway bar bushings
we ordered all the parts - most everything is working out ok (still gathering a few pieces to make the rear coilovers work right) - i expected some issues along the way as some of this had never been done before - i'm actually having some parts made for this conversion, and even that looks good
what i did not expect was trouble with the OEM parts ordered from porsche
we ordered the bushings from sunset - we confirmed the part numbers with 3 sources first - the parts came in today - the bushings for the front came in the standard little porsche parts baggies, and are correct - the ones for the rear did not come in baggies or have any porsche tags on them - they did have the part number on the part itself - it is the same part number in the pet and the other parts list i have, as well as at sunset - one would think that this would be correct - it does not look like any mistakes were made anywhere in the ordering or fulfilling process
however, the part is the wrong size! - the I.D. measures 17mm - the bar is 19mm - this creates a huge gap that will not allow the bushing to fit within the confines of the bracket - if i cram it in there, the bushing will bind and prematurely wear, as well as have a preload all the time
so, for those of you out there that think that OEM parts are flawless, or the PET is always right, guess again - either the PET is wrong or the manufacturer blew it - either way, we got a part that does not work, and now get to try to sort that out before wednesday
www.968forums.com
