Threads: 77
There not the most accurate. They are also feed by a electrical signal from the KLR which has a vacuum feed from the intake. So you will need to find some way to replicate that electrical signal.
(This post was last modified: 01-06-2011, 10:06 AM by
banditsc.)
Threads: 77
Not sure which connector. There is plenty of empty space at the bottom of the existing tach, why not add in a small digital boost gauge there?
Threads: 77
Threads: 77
That same site has those square gauges in anything you want. They even have a AFR that talks with the Innovate that looks exactly the same as the boost gauge above.
