NASA...We have liftoff!
Fellows,
I've just come back from shop (Paddock Performance) and we've corrected an existing A/F problem that old shop didn't correct...and did a few other things.
Mustang dyno runs done at 18.5 lbs of boost now produce 424 HP at 5,667 RPM and 391 lbs/ft of Torque!
When the boost is turned down to a more modest 15.5 lbs, the resultant numbers drop to 371 HP and 336 lbs/ft of Torque...Plenty of oomph
for me; while maintaining a bullet-proof monk!
All the while maintaining an A/F of around 12.1 to 12.4.
So, what would those numbers be if they were translated to flywheel HP and TQ figures?
Jason
I'm not going to guess at the translation but I like the sounds of what your have at the rear wheel.
Jason,
I've seen a 22% driveline loss on a 24" dual wheel Mustang and a 17% loss on a single 36" wheel Mustang.
Both numbers put you in the "Scary Zone"
I actually like to see 11.4 to 11.8 AFR on turbos to be on the safe side.
Pete
Pete,
Thanks for the suggestion...I'll see if they can fatten up the fuel ratios a bit.
By the way, it's a single wheel Mustang, so I guess the lower number is more correct.
Jason
