Threads: 45
Just wondering about this must be OEM, just out of interest what page of the PET catalogue has the part number for the supercharger and inter cooler.
Or should I contact my local Porsche centre?
Threads: 45
almost, (in Reply to Williammoss)
the wire would have to be exactly the same diameter and have the same electrical resistance, as I would guess the device is calibrated before its sealed up by Bosch.
but there are cheap alternatives that are electrically the same just a bit physically different.
the wire is cooled by air flow which allows it to calculate the mass of air flowing by, if the wire is larger it has more surface area so cools quicker but heats slower, at this point the maths completely out pace my limp brain
so I would suggest you can get quite close but to be dead on would be pure luck.
I doubt very much is the ECU can cope with massive changes of data from the MAF as its expecting a set of parameters that were designed in.
It would be an interesting exercise to compare an old MAF against a brand new one, to see if the throttle response improved in the same way as wildcat has experienced
(This post was last modified: 08-21-2015, 02:57 PM by
Waylander.)
Threads: 45
bit more reading if this subject interest you
Threads: 45
We have taken a gamble here to test a few, the best candidate is 0208 213 012 this fits some big engined volvos and has the same connections and electrical properties,
The only difference is instead of the wide plastic screen in the intake there is a much finer mesh, they use this MAF on Ferrari but two of them
We found some on eBay for as little as $45 new but cheap copies, but even genuine Bosch is a load cheaper than Porsche price at $1000
I will let you all know how it pans out
