06-22-2011, 02:49 PM
I'm trying to build a mathematical model of the 968 braking system as a learning exercise to help me understand how all the components work. This model will calculate brake torque based on pedal pressure (assuming 100% efficiency of all braking components). It will compare and contrast various brake kits upgrades for the 968 (M030, Big Red fronts, and Big Red fronts with OEM fronts on the rear), accounting for the following factors:
It will, of course, be posted here when complete, but first I have some questions that I need help with:
- Pedal pressure
- Pedal leverage
- Brake booster boost
- Master cylinder piston area
- Bias valve pressure reduction
- Caliper piston area
- Caliper piston leverage
- Pad coefficient of friction
- How do I determine the contribution made by the brake booster?
- The OEM master cylinder has different piston sizes - circuit 1 is 15/16" and circuit 2 is 13/16". Circuit 1, with its larger piston area, goes to the rear brakes to ensure the rear gets less line pressure, correct?
- The bias valve reduces rear brake line pressure above the "knee point" of 18, 33, 45, or 55 bar by a certain percentage. What is this percentage? I have found conflicting information - in one place, I read the 5 in 5/33 means 50%, in another place, 46%.
- What is the height of the friction material only (not the backing plate) for the M030 and Big Red pads? This statistic is needed to approximate the caliper's leverage on the rotor.
(This post was last modified: 06-22-2011, 04:34 PM by pure&simple.)
