02-01-2005, 09:17 PM
What did the M030 option include?
Posted by Raj Datta at 968.net
17 inch wheels
Front Bigger brakes with bigger calipers as well( 928 S4 kind)
Front and rear cross drilled rotors
30mm Front sway bar, 19 mm rear 3 way adjustable sway bar.
Usually comes with option 220 (lsd)
Adjustable shocks, front are adjustable for ride height and rebound damping.
Helper springs on rear shocks.
The front hubs/spindles are different as far as mouting points are concerned.
It was almost a $3k option. If you were to price all the items seperately, its close to $6k.
Posted on the PCA 968 Q&A area:
I just purchased a 93' Porsche 968. It came with the factory 17" wheels. I checked the list of option codes in the hatchback area and there was no listing for M030. What are the modifications required to upgrade a standard suspension to the M030? Also, how would the handling change if I put on 16" wheels? I use the car as a daily driver, but want to get into autocross and track events. Thanks! Pete
You will need the following to convert to 968 M030:
951.341.655.34 steering knuckle 951.341.656.34 steering knuckle 951.341.065.08 hub (2 needed) 944.343.031.28 left koni shock 944.343.032.28 right koni shock 944.343.531.01 springs 951.343.524.00 adjusting nut (need 2) 951.343.525.32 concave washer (need 2) 951.343.529.30 boot (need 2) 133.412.341 concave washer (need 2) 999.703.355.40 cap (need 2) 944.343.706.30 front swaybar 944.343.794.05 bushing (need 2) 951.343.793.31 bushing (need 2) N.012.449.1 lock washer (need 2) 944.333.032.03 koni rear shock (need 2) 951.333.531.31.504 rear springs 944.333.526.01 concave washer (need 2) 944.333.701.01 19 mm rear swaybar for manual trans 964.333.792.00 rubber mounting (need 2) 965.351.041.01 driver side brake rotor 965.351.042.01 passenger side brake rotor 928.351.421.03 driver side caliper 928.351.422.03 passenger side caliper 900.067154.023 bolts (need 4) N.011.564.2 washer (need 4) 993.351.939.01 brake pads set 928.351.950.00 spring (need 2) 928.351.971.00 brake line (need 2) 951.351.089.03 vibration damper
The handling would not be as crisp with 16 inch wheels, due to the additional height of the sidewalls.
George Beuselinck - PCA WebSite - 8/19/2002
17 inch wheels
Black 03' Turbo X50
Black 05' Denali
