Quote:out of curiosity for the less informed as myself included, what are floating brakes, and what are all those stainless lines around the rear end?
Floating or 2 piece rotors are when instead of a one piece rotor that includes the hat, the hats are separate from the rotor and connected with fasteners or whatever the terminology is in the US. In the first pic you see the Big Red calipers with the oem Porsche 322mm 1 piece rotor. The 2nd pic shows what has eventually wound up on our car with 2 piece floating / slotted 375mm rotors and Alcon 6 piston monoblock calipers. They tend to fill the 18" wheels up quite a lot now.
The stainless lines have replaced the stock hardlines for the rear brakes. The weight saving on the rear between the fixed rotor and the 2 piece. 1kg = 2.2lbs of unsprung weight. I don't know what the weight difference is between a single front 1 piece rotor and our current ones but they'd be pretty similar even though current ones are much larger.
