Kokeln control arm failure
Also posted on another forum, but thought it is of interest to others since it is safety related.
I was on track last weekend and whilst just starting to brake from around 100mph into a hairpin the front of the car collapsed on one side. The control arm had given way, wheel up in the arch causing damage, and ended up in the gravel trap (rather fortunately).
For those of you that know these arms, they have a threaded collar that sits in the end of the arm complete with a lock nut. A rod end then screws into this threaded collar again with lock nut. The rod end has a bar/rod that fits into the hub spindle.
It appears that the threaded collar has given way - sheared - with the rod end in it leaving the other half of the threaded collar in end of the control arm.
Obviously i am not very happy, i have damage to my front fender, brake line, wheelarch liner, steering arm etc. I spoke briefly to visionmotorsports (receptionist?) after i sent a mail to Kokeln and received no response. The contact number on the then Kokeln site directed me straight through to visionmotorsports. I have resent my mail to them earlier this week and await their response.
A couple of questions - does anyone know what association visionmotorsports has/had with Kokeln, and am i likely to have any fallback/meaningful resolution or response?
Has this occurred to anyone else whom have this control arm, or indeed, this type of control arm.
The threaded collars and locknuts allow for adjustment at the bottom of the arms (camber), i have reservations with the design in the extended mode. If the collar is fully threaded into the control arm, and the rod end fully into the threaded collar they appear quite robust. Once you start to adjust the collar/rod end outwards, there is less of each component in the preceding component, i.e. collar and control arm.
You can determine from the photos (the rod ends are fairly dirty/greasy) the associated dimensions. Rod ends at this size have 43mm of thread. The picture shows how they were set up on the car, the problem being there is only 10mm of combined rod end and collar in the control arm. Which i now know why the other side sheared - I think the assembly has worked loose resulting in little or no combined rod end and collar in the control arm overstressing the collar resulting in shear!
Is the maximum of 18mm of combined collar and rod end in the control arm sufficient, if all is screwed as far in as the collar/rod end will go?
Iif i can obtain replacement collars threaded upto the underside of the nut part, i will screw all the way in (and possibly tack-weld) allowing c28mm of combined collar and rod end in the control arm. This does remove the adjustment function though.
If you have control arms similar in design to these check them out - make sure you have sufficient metal in metal!
JP
[Image: CIMG0722.jpg]
[Image: CIMG0713.jpg]
[Image: CIMG0716.jpg]
Posted this over in the other forum also, check out this thread. http://www.968forums.com/index.php?showtopic=5441&st=40
....and considering i posted on this thread...
http://www.968forums.com/index.php?showtopic=6275
"Perhaps my main concern is the catastrophic failure that occurs, potentially mid corner etc"
JP
i would contact pete - he knows the skinny on the current status of kolkeln, as well as the ins and outs of different control arms - they have been located inside the vision building for some time, but ownership and operations are or were changing
I am so glad you are ok and the failure caused no major incidents....
#75 RS Barn-Hoosier-AJ Hartman Racing Porsche 968
2012 PCA GT5S NORTH ATLANTIC CHAMPION
2011 NASA PRO RACING (NE) GTS-2 CHAMPION
Track Records: Pocono Long Single Infield CCW | Pocono Double Infield | NJMP Thunderbolt w & w/o Chicane | Lime Rock Park
A lucky escape Pablo, and one i don't want to repeat.
JP
Last Post by AJG
07-20-2012, 03:59 PM
Last Post by Seven30
11-01-2010, 04:09 PM
Last Post by RS Barn
03-26-2007, 10:54 PM
Last Post by Mark
03-18-2007, 07:56 PM
