[quote name='flash' post='36287' date='Jun 1 2007, 07:00 PM']i put it under the frame at the front of the car - no wood - i'll have to measure it to tell you how high it was, but i'd guess about 14"[/quote]
Thanks, but could you tell me how far in front of, say, the front of the door? Just want to make sure I make an accurate comparison. So, of course, I'll also need to know the air temperature, relative humidity, air pressure in all four tires, transaxle oil temperature, power steering fluid viscosity, the pH of the coolant, and the serial number of the jackstand <img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" /> .
Seriously, I'm really interested if I see a similar change when I install the lower suspension brace in my coupe. I'll post before and after pictures.
By the way, aren't you concerned about putting your car on a jackstand without a good sized block of wood to distribute the load? I always put a 2 x 4 that's at least a foot and a half long between my jackstand and the car. I place the jackstand under those rails are maybe a couple of inches wide, protrude a couple of inches below the bottom of the car, and run vertically the length of the floorboard. Thanks.
