02-21-2025, 01:59 PM
Yesterday after an uneventful half hour drive and three different stops for various errands, just about a minute after I left the last store, when I stopped at a traffic light, the engine suddenly stalled . I started it again ( in a panic because there were several cars behind me, and the first one did not seem to have any space to drive around me, nor could he back up without the other cars behind him backing up, causing traffic havoc...but I digress ..) . After starting it, the rpm needle was jumping all over the place, racing, stumbling, etc. I drove it for about 4 blocks ( and that was a chore, as it was hesitating to accelerate, and showing signs of near stall again , so I kept it in first gear and high rpm ) until I got to a nearby parking lot . From quite a few previous similar experiences I knew this was the DME relay failing . Lucky I always keep a spare DME in my glove compartment . So I switched it, and sure enough, the car idled perfectly right away, and the drive home was without the slightest symptom of anything being wrong . I always keep a spare DME in the garage also, so they’re always in stock .
The only other time I’ve had the car stall out it was due to a vacuum hose disconnecting, but the stall out when coming to a stop has always been the DME . I probably went through a dozen DMEs in the last 25 years or so ..
