Threads: 5
They do not look like they are directional. Did you try having them remounted inside out?
Sounds like you had a lot of fun with those tires!
Threads: 5
That wear pattern is typical of tires that haven't been regularly swapped side to side and flipped on the rim. I just corded two front Toyos and got at least a dozen days out them. The difference is that I'm fanatical about swapping the tires side to side. I usually swap the fronts twice a day, and the rears once. Don't worry about the directional tread pattern. It means nothing in the dry. When the outsides of the fronts look like they're getting close to cording I have them flipped on the rim, which effectively doubles the number of days you can get out of them. I keep a close eye on the rears, but I can usually get away without flipping them on the rim.
In looking at your pictures you can tell that the outside left front got most of the wear. This is typical since most circuits are clockwise and have more right hand turns than left. You can see that the inside of the right front also got a lot of wear. This is because in a right hand turn the right tire is unloaded with the inside of the tire more in contact with the pavement. Swapping and flipping evens all of this out. If you looked at the front Toyos that I just wore out, you'd see that the wear is almost perfectly even inside and outside and left to right. The tires finally corded on the insides, both during the same session! Another session and both the outsides would have been showing cord.
You asked about alignment, and you might want to try running more negative camber up front, as that will cut down on the outside wear somewhat. However, that's not a substitute for swapping and flipping if you really want to maximize the life of your tires. Your pressures are exactly what I'm running, and I'm getting good results, so I wouldn't change anything there.
BTW, these wear patterns are not peculiar to Toyos. I've experienced the exact same patterns with Hoosiers, MPSC's, Kumhos, and the old BFG R1's.
Jim Child
'94 968 PCA E-Stock/NASA GTS2
'01 Boxster
