Threads: 15
I got some VDO gauges for the Design1Racing 3 hole gauge plate; a dedicated Boost Gauge, Vacuum Gauge, and Air/Fuel Ratio Gauge. Now I need to figure out how to make them functional as well as interior decor.
Has anyone else hooked up the boost or vacuum gages from VDO? They sell a tubing kit that uses a 1/8" line, I was thinking of finding and adapter to a 3/16" barb fitting instead to hook up to vacuum line.
Also any thoughts on where the best place to pass through the fire wall or splice into the vacuum tubing would be?
Threads: 15
I saw the combined gauge and figured it would work, but it had turbo printed right in the middle of it so I thought dedicated gauges would look cleaner in the cabin. It sounds like I'll be ordering that turbo gauge; with the D1R SC kit the maximum the gauge should ever show is 5 psi correct?
(This post was last modified: 07-03-2013, 12:51 AM by
986boxster1998.)
Threads: 15
Thanks guys! I found one that could work and provides the additional bar scale, it does look a bit more cluttered though:
(This post was last modified: 07-03-2013, 12:12 PM by
986boxster1998.)
Threads: 15
This is what I purchased for the third space, I'll have to think of another gauge now that the Vacuum/Boost will be in one gauge and might go with the oil temp gauge. This one's an Air Fuel Ratio and is on it's way from Australia (hopefully its fairly straight forward to hook up as I'm not yet sure if I need an additional sensor welded into the exhaust or if I can tap into the stock oxygen sensor):
(This post was last modified: 07-03-2013, 04:23 PM by
986boxster1998.)
Threads: 19
I used Autometer gauges in my Mazda/Ford. Like Flash, I prefer the 270 degree sweep. I had the led, as I liked the fact that the color was easy to see without even looking. I think there were about 16 leds making up the 270 degree sweep. If you are running boost, there is a big difference in the safety factor if you're running rich at 13.8:1 vs 12.5:1, or 11:1. You'll want to be able to distinguish between these a/f ratios. hThe one you have shown has so few leds that there isn't a lot of definition. They also make gauges that have a digital readout of the a/f in addition to the 270 degree sweep around the perimeter so you can see the actual a/f if you want.
'92 Midnight Blue 968 Coupe
Threads: 19
[quote name='986boxster1998' timestamp='1372879311' post='145217']
You should have no problem hooking into the stock oxygen sensor. In fact, my preference is to use it since it is what the DME is seeing. So, you might as well be looking at the same signal for any troubleshooting benefit it will give you. 3M makes in-line crimp on connectors that allow you to tap into an existing line. I've used them extensively in the past with never an issues.
Threads: 15
I did some searching and found other analog gauges, I was just stuck on having all the gauges being VDO. The gauge I ordered is a wideband with 10 LEDs so it sounds like I'll need to get a wide band sensor. Good to know centrifugal unit maintains mix better then others.
