Threads: 56
I have a oil sump drain plug from Lindsey with a 1/8 NPT fitting for a temperature sending unit and I am now looking for a nice looking oil temp (and trans temp and oil press too) gauge. I am thinking about these
http://www.speedhut.com/gauge_products-a...lution.htm but I am not sure. You guys with extra gauges, what make do you run?
Threads: 12
I could not find a VDO boost/vacuum gauge that didn't have "TURBO" printed on the face so i went with NewSouth
http://www.newsouthp...om/spectrum.htm. They're LED backlit and it matches the blue LEDs I put in the instrument cluster and dash.
I also use a NewSouth oil temp gauge with the sender mounted in a plate that fits under the oil filter
http://prosportgauge...ptor-plate.aspx. It works with the Canton filter and it includes additional ports to add a pressure sender.
Brian
'94 black over cashmere cab, 6 speed, lsd, supercharged
Threads: 56
Thanks, I'll check egauges for VDO. The newsouth gauges have, IMO only, too many lines in them. And yes, they'll go in the slot below the stereo.
Threads: 56
Threads: 56
Waiting to be installed.
Where do I put the oil pressure sending unit?
Threads: 56
Hmm, I wonder if it's possible to "steal" a signal from the stock sending unit, provided that they match? But that is a little bit of missing the point of having two gauges...
Threads: 56
I only really wanted the temp gauges but opted for the oil press too in order to fit the empty slot next to the two. But I like the idea of being able to set high and low pressure warnings and hooking up an external light (ie like a shiftlight on the dash that triggers at say 1,5 bar) since my steering wheel blocks the ! and I certainly don't have the time to check the pressure gauge at close enough intervals to avoid damage due to oil starvation when hammering around the track.
