06-06-2010, 09:26 AM
Most of the head gaskets that fail in these cars fail due to corrosion on the coolant side. Dissimilar metals, poor water quality, coolant that does not protect well, and time conspire to eat the gaskets up. Change that coolant, use good coolant, good water. 'Refresh' the coolant at least once a year by getting some of the older stuff out and fresh coolant in so there are fresh additives in there to keep the chemistry in balance. A wet vac works wonders for getting coolant out, or a suction gun.
The modern coolants seem to stay a nice bright cheery color even long after the additives are depleted and the chemistry is eating away at your internals, so if it looks clean that means nothing.
I do not suggest you change your HG before supercharging your motor. If you have tuning or fuel quality problems your HG might burn through and you might as well burn up an old one. You could benefit from decarboning the engine, which you might do when you swap HGs but you can also do that with some water injection without pulling things apart. Yes you might need a general head rebuild but for my money I'd much rather poke around in there after 1000 supercharged miles than just before I strap on a blower. I suggest budgeting for a head refresh, but consider using the opportunity to see how the motor is doing on boost.
I am at a decision point with my SC setup and will probably put a 1.4mm tall gasket in if I tear into the motor. I need to get the SC migrated to my 92 which has a fresh head but I assume it has the weak rods and it might need an oil pickup tube. I have a set of forged rods to throw at it, so despite the fresh head it might be coming apart. I'm tempted to just pull the oil pan and see what's up in there, strap on the SC and go. I suspect the rod issues are a result of detonation so with water injection, quality fuel and good sense they might not be an issue. It's possible they have already been changed out too I suppose. I do not particularly want to pull the oil pan and then decide I should pull the motor, but I guess I could pull the head and do the rod swap with the engine in the car but I'd rather have the motor on a stand and all winter to monkey with it. Since the last time I pulled a 944 motor I took it out the bottom maybe it's no big deal but I was thinking I'd go out the top this time. Hmmm.
-Joel.
-Joel.
