Threads: 20
Thinking seriously about an upgrade to 9x18 fronts and 11x18 rears. I think Flash has the lowdown on the fronts, yes? But who (Matti?) has the mysterious 11x18's installed out back? [img]style_emoticons/<#EMO_DIR#>/dry.gif[/img]
What I'm after is offset numbers if you've got 'em. Thanx!
Dan
'95 968 Coupe
James Dean
(This post was last modified: 02-09-2010, 11:26 PM by
Lonestar968.)
Threads: 20
Flash: On a street car, how much lateral movement is typically experienced? Heck for that matter, how much on a street/race or just plain track car??? How much flex in Delrin or similar bushings??? This is interesting stuff! [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]
Dude: I'd be interested in whatever numbers and info you can provide.
I really hope to see if somebody's already done the homework/mock-up/test-fit just to save a few bucks and some time. There are a lot of great (garage) racers out there who have probably tried this stunt before.
I understand the suspension geometry is a factor with interference as are the wheel openings and such. I'm not all "Joe wheel engineer" or "Jimmy race car driver" or anything like that, I just want to see if I can fit some fat ass tires under the car and still be able to drive it. You remember, like back in the day... something like what you probably had under your '66 Mustang or '69 Camaro!!! Remember how cool L60x15's looked back then?!! [img]style_emoticons/<#EMO_DIR#>/cool.gif[/img]
Dan
'95 968 Coupe
James Dean
Threads: 20
How wide a tire will fit on a 10" wheel at about a 54mm offset and not rub the inner lip?
I'd love to run 9" fronts (I believe Flash has them on his car, yes?), but what offset?
Do you know if there are any rear suspension differences between 968 and late 944/951? Perhaps alignment settings might be different or something? Or maybe the 944/951's had more room in the wheel well to begin with?
Dan
'95 968 Coupe
James Dean
Threads: 20
Wow, that sounds like way too much thought just for fat tires. Better sleep on it. I might just have to settle for the 10" wheels and call it a day.
With that said, how fat can I go on a 10" wheel in back without sidewall distortion?
Dan
'95 968 Coupe
James Dean
Threads: 20
Thanx for all of the great input everyone! And especially thanks for the heads-up on the spindle stress factors, Flash. I do want to track/DE my car once in a while so avoiding unnecessary repair expenses as an afterthought, or track specific ($$$) upgrades as a forethought, are points very well taken.
Seems like the bang-for-the-buck ratio doesn't warrant 11's. At least not yet (how the heck do the 944 guys do it???).
And it also seems like the general consensus is to stick with 10" wheels with 285x30 tires for the fattest yet manageable profile. That'll have to do. At least for now. I still want to add a tunable suspension one of these days and it seems logical to think lowering the car will only exacerbate the interference issue. Hmmm... I remember someone in another post talking about losing the torsion bar housings et al since they're already running coil-overs. Perhaps someone (uh hem...) will feel compelled to design a new, improved trailing arm that will allow wider wheels without interference or suspension compromises. Just throwin' it out there people. Just throwin' it out there.
Conversely, if the SC kit yields the necessary power/tq required to offset the additional drag/rolling resistance, maybe 11's aren't completely off the radar screen quite yet. And if "all" it takes is a set of M030 spindles to safely hang 9's out front, the dream is still alive!
Dream like you'll live forever... [img]style_emoticons/<#EMO_DIR#>/cool.gif[/img]
Dan
'95 968 Coupe
James Dean
Threads: 56
Flash, how fat are your sways? Like the Tarret or meaner?
