That's correct; thanks for pointing it out. I suspect 968s with high mileage, unless there's something really wrong with the engine, aren't actually down on power a whole lot vs. when they were new. As evidence, most people who have been forced to have at least top end rebuilds (for things like broken belts) haven't noticed much, if any, by way of improved performance. Also, when car magazines do long terms tests on cars, and check acceleration at the end of the test period, they're usually as fast as, if not faster than, when they were new. I recognize that this is typically after around 60K miles, not the 100K+ that so many of our cars have, but I can tell from my own experience in rebuilding my engine at 116K miles that the valve seats were almost as good as new, and the cylinder walls showed essentially zero wear (not sure about the rings, though), but I suspect they were fine as well, as rings aren't known to wear very fast on these engines If you take good care of them, these engines can go a long way.
Unfortunately, they do have a weak link in the head gasket, but if you're really pinched for cash, and are handy with a wrench, yanking the head at around 80-100K, and slapping in a new gasket, and nothing else, should carry you to upwards of 200K if you take good care of it, imho.
