Headlamp & driving lights upgrade/replacement
Fox, I know what you mean about the Audi lights. They cut off so sharply and so low that your forward vision isn't as good as it could be. I bet the euro version are OK.
Has anyone discovered a LED bulb that would go into the stock headlight socket? I have already put in the PIAA h4 bulb which did improve the stock bulb but an LED I think would be terrific.
There is a guy over here that sells kits for the 944/928 not sure if they will fit a 968
Woodypeck.com
The driver-side headlamp lense got hit by a rock.
Ordered a new one through Pelican Parts - had to come from Germany!
Printed off the DIY in this thread to help replace it. Thought I would keep the old one because it was only cracked, until I removed it and found this inside:
I put Hella Off-road racing 80/100w bulbs in four years ago. No issues with them at all other than the speed limit signs reflecting the light back
Last Post by Ryan
09-06-2018, 09:57 AM
