Hey guys-
Sorry it's taken me so long to chime in... I'm actually trying to start some sort of website to help answer questions, etc & am trying to expand into a few other things, but really, the "Higher Connections" name was just something for Flash to put on a banner. I'd like to change it, b/c I'm really just a guy who loves these cars & fell into building battery & headlight cables for them.
I bought a 1988 944 Turbo S in late '99. I really wanted a 968, but they were a lot more expensive then. I met Dan Wray (IceShark) on Rennlist in '01. I never met him in-person, but he'd done some custom work on his 951's headlights, battery cables, & grounds. Several of us prodded him into the headlight thing- I'll outline below. In summer 2004, there were a few underhood fires, due to worn out battery cable insulation, so Dan started making new battery cables. Unfortunately, he died in late 2005- I bought the rest of his inventory & went from there.
The 944 headlight kits- he built a harness w/4awg main power cable, Hella waterproof relays, fuses, ExFlex protective sleeving, 4awg supplemental ground, adj voltage regulator (at 14.4v), Cibie e-code lenses, & Narva H-4 100/90w bulbs. The dif in lighting output was literally about 4X over w/a sharp cutoff (ie- would not blind oncoming traffic if aimed properly)- it all worked together- I'll explain if anyone wants more detail. They basically transformed inadequate lights into excellent lights, comparable to the best on the road in ~2003.
The prob is the cost- the full kit for a 944 is ~$400 & it brings up the lighting output by ~400%, whereas the 968 is ~$640 & brings it's lighting up ~50%, if that... I'd like to see if just adding all of the grounds, an adj volt reg (a bitch b/c you have to get to the alternator) & better bulbs wouldn't help a good bit. The 968 lenses are ~$360/pr! They're ~$130/pr for 944s. The next prob is relays. The Hellas are overkill, maybe, but then, that's what Dan used & I'm trying to find the same ones & will give it just a little more time. Otherwise, I might have to source something different.
Does anyone have any pics of the lense / bulb, close-up? I'll see if I can come up w/some options. If anyone here is really interested in that, I can pursue it. Otherwise, I'll keep looking for the relays, to at least do the harness.
Would anyone here be interested in the harness w/out lenses? Several of you had contacted me about this & I'd mentioned Daniel Stern for lenses. But I could get them for same price & just sell as a kit, but if the thing is, if you converted to a dif bulb w/the harness, I'm wondering if your lense would allow the bulb to fit into it & work...? I've forgotten the style bulb you guys use- is is H004 or something? You guys can all reach me at rkc951 AT yahoo.com
