i'm pulling this one out of the archives. hopefully someone will read it. <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
in the process of installing my new ice shark battery cables, i decided to clean up all the ground points. some were very difficult to access and i couldn't even find two of them.
could someone please enlighten me as to the location of gp i or vii in the rear? i found the one just to the left of the hatch mechanism where the hatch release motor ties in (and perhaps the taillights?). it's the one you use for a keyless system. i'm not sure if this is #i or #vii. but the other point back there.... i just couldn't find it. it was late and dark, so please be kind...
also, number ix and x. i found the major ground where the negative battery ties in. i'm guessing that this is x, right? then there should be one just foreward of that, but i couldn't find it? i did notice that there was a smaller wire also grounded with the large battery cable. does this jump up to anther point? i'm really hoping that it isn't under the manifold. i just don't want to remove that to clean a ground point!
thanks to anyone who takes a minute to help.
by the way, cleaning the gp's is time very well spent. everything is working better now. wipers, windows, gauges, inst lights. the only real bear was gp ii, which is actually two points under the fuse box!
