Guess what??? Problem solved!!
I drive over to my friend's shop and we start checking every fuel line, vapor line, what we could of the tank, form front to rear and NO leak. Man, it sure smelled on the way over, though! Weird. Must be a hole on the top. But I clearly remember checking for mounting holes BEFORE placing the sound deadener and there were only four into the back of the driver side fold down rear seat from an old bazooka sub.
All lines checked again. The tank held 20 psi pressure without ANY smell or leaks. Also started the car and giggled it around to try to get the smell going while on the lift....NOTHING!!
So then I noticed the engine was running kinda rich because with the car on the lift, the tailpipe was right at our face level. Then I rememberd that I had a loose heatshield so I start looking for it. ALL tight, and I mean really tight.
So then I shake the exhaust and there is the rattle, really bad, coming from the center resonator. I noticed three hoseclamps over three holes. Apparently, these holes at one time held screws which held the inner baffle in place. They were rusted out and missing and we could shake the baffle around by shaking the exhaust. And when the car was running, these three holes were leaking exhaust pretty badly....(So why make an all stainless exhaust and use freeking iron screws to hold the baffle in place?????dumb asses...)
So what to do....hmmm. I took down the rear end of the exhaust. Put it under the band saw and bisected the resonator. out fell the cheese grater baffle and some old screw bits.
I made up an angle iron jig and welded the three holes shut and welded the pipe back together (although I was too lazy to go home and get my argon stainless welder and ended up using my friend's brand new Lincoln steel welder...it has autofill/feed which is really nice..adjusts for gap and arc automatically...does not have stitch, though). ground off some slag and used some high temp paint on the seam.
On the drive home, while enjoying the slightly richer exhaust note, I took some hard turns. Hmmmm , no more gas smell......WHOOHOO!!!
We did not realize at the time that we had solved the problem of the gas smell in the cabin by welding up the exhaust!!!
Now to find out why she is running rich.....O2, mass air sensor... etc.....for another day...
in the pic below, you can see two of the three holes and my new seam. Oh , by the way, this adds 2.3 horse power and she feels SO MUCH faster....just kiddn..
