Fuel Injector Cleaners. Are they safe to use?
For some odd reason I decided to use a bottle of fuel injector cleaner with yesterdays fill up. <img src="/forum/images/smilies/968/ohmy.gif" class="smilie" alt="" /> Car seems to be running well but the check engine light appeared this morning but went off after 5 minutes. Therefore -- how do my fellow 968 members view this stuff. Is it BS? Does it really help? Or if am I looking for engine trouble by using it?
well, as long as it is fairly new, and a major brand, it should be fine
this assumes you are following the instructions on how much to use and such
Not exactly on topic, but I blew a set of spark plugs with too much octane booster in a GMC Yukon.
Tom
I use Chevron Techron regularly (about every oil & filter change) and feel that it keeps my fuel injectors and valves clean. Never had any problems from using it. Good luck, Bob Blackwell.
[quote name='bob blackwell' post='42203' date='Oct 10 2007, 01:18 PM']I use Chevron Techron regularly (about every oil & filter change) and feel that it keeps my fuel injectors and valves clean. Never had any problems from using it. Good luck, Bob Blackwell.[/quote]
Same here. <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
I too used the Chevron Techron cleaner - however, I think the problem is or was the fact I poured two bottles of it in one tank of gas. Which BTW I forgot to write in this original post. So please be kind when replying to this post about my stupidity.
"If a little bit is good........" Then a little bit is all you need, good luck, Bob Blackwell.
yup - that was what i suspected, and why i made the above qualification
likely no damage - just don't do it again
I used more than specified in my truck and it fried one of the o2 sensors very quickly.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
Last Post by unknown4u
09-29-2017, 02:51 PM
Last Post by DaveN
07-25-2013, 04:30 PM
