Threads: 5
I would bite the bullet and replace both rear tires.
Jim Child
'94 968 PCA E-Stock/NASA GTS2
'01 Boxster
Threads: 5
John,
I assume that you are only planning to use the fix-a-flat until new tires that have already been ordered arrive?
I have been in the same situation, with an unrepairable tire and no replacements available locally. Fix-a-flat will work, but as Dave said , the guy who changes the tire will not enjoy the goo. The plugs Dave mentioned are available at places like Walmart and Autozone in DIY kits. You can use those plugs in the short term.
I drive my 968 too fast and too hard to take risks on worn or damaged tires. If it were me I might drive carefully on the DIY plug for a few days to get by, but would order all four or two new rear tires asap.
