Finally - use DEXRON III in P/S!
Going by the fact that we're supposed to be using DEXRON II, which is no longer available.
The folks on the oil forum said that DEXRON III is backwards compatible with II.
So, tonight I'll add some DEXRON III to my power steering reservoir!
<img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" /> <img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" />
Case closed...
Michael Sorbera
aka San Antonio Silver Bullet
2002 VW Beetle TDI
2004 Nissan Titan Crew Cab
1990 Mercury Grand Marquis
I topped mine up with Dexron III after a leak from the clamps at the bottom of the reservoir.
Then I replaced all the fluid with Redline "SYNTHETIC ATF" from Paragon which is described as "synthetic Dexron II, Mercon, and Mercedes-Benz approved fluid. Superior stability allows high-temperature operation without varnishing valves and clutches. Also provides improved shifting in cold weather."
Last Post by Simuse
02-28-2006, 12:45 AM
Last Post by bob blackwell
03-20-2005, 11:31 PM
