Engine Removal
Hello all,
The 968 is leaking oil; has been for years. I can no longer stand it. I want to get the engine out and put in a new oil pan gasket, and check the seals. I think the rear seal is leaking also.
I can follow the Clarks. procedure and remove the engine out the bottom. Or, I can try to get the engine out from the top. Is that do-able? Anyone ever tried it?
Pat
I've heard it's possible to remove it from the bottom, but I think you need a lift to do it - conventional jack stand can't lift the car high enough to clear the engine from below.  The manual describes how to lift it from above, which is the procedure I followed.  Definitely a big job.  It really helps to have a load leveler, and a second set of hands while lifting it out.  You also need a set of metric curved wrenches to remove the top bolts for the connection between the torque tube and the bell housing.  I bought a set from Harbor Freight, and they worked very well.  Good luck.
It is possible to replace the seals without removing the engine. Just another option. I got mine to be bone dry for years now.
Bulti,
That's great to hear.  I tore my engine down to the bare block, and carefully re-sealed the balance shaft covers (along with of course replacing all of the seals and gaskets), and didn't see a drop of oil on my garage floor for about six months.  Then, it started leaking again, so I'm of the opinion that this is pretty much a "luck of the draw" type of thing - it depends how flat you various mating surfaces in your particular engine are.  In general, these are just leak-prone engines.  I'm tempted to move on to something like this one of these days:
http://www.motorwerksracing.com/porsche-...-18t-swap/
I'm assuming that they could make something like this work for a 968, although of course the 968's bell housing design is different from the 944's.  But for a price, I'm sure anything is possible.  Of course, mine is a track rat - I wouldn't do something like this in a street car, especially if there's a chance of the 968 appreciating in value in the coming years.
Cloud...interesting link. That 1.8 is super light.
The pan gasket can be changed by dropping the cross support and suspension while using a top motor support.
If your going to do a major reseal, then pulling the engine and doing the work in a stand is WAY easier and more time efficient than with the motor in the car.  You'll have to pull the engine for rear main and/or balance shaft housing reseal. Out the top is how the factory manual describes and is how I have done it.  Some like from the bottom, but you'll have to have a way to get the car up high enough to clear the engine when it's on the ground. The factory workshop manual is a big help with this job.
Hi Cloud, it's been a while. Looks like a great way to go, altough it would change the character of the car significantly. But it sure looks like these guys know what they're doing. How deep are your pockets ;-))
I wonder, is it the VW/Audi block?
Re oppositelock: I changed EVERY gasket, except for the balance shaft seals. But those can be sealed with a good heat resistant RTV silicone. Holding up fine for a few years now.
But, if you have the means and skills, I agree that pulling the engine would definitely be a more efficient way to seal things up and clean everything.
Cloud wants to run with the big boys!!
Last Post by Bulti
08-25-2014, 01:50 PM
