Dynolicious - awesome iPhone application!
Just downloaded this app for my i Touch. What a cool toy, but am also concerned about the ipod taking collateral damage! Certainly not expecting it to replace a full dyno but for $15 what do you expect. Will post the data when I've found a suitable road.
i ended up just putting the drive train loss at 0% because it says to do that to get power at the wheels. i included all weight in the car (including my massive speaker set up :/) did a couple runs today... heres the read out:
0-60: 6.67s (i dont know how to launch though, any tips?!)
0-100: 13.73s
1/4 mi: 14.74 @ 102.3 mph
max acceleration: 0.92 G's
peak horse power: 269 @ the wheels
mods:
rs barn stage 1 chip
rs barn cat back
airbox mod
the heads been milled down... MORE COMPRESSION!!!
4 way valve job
269 at the wheels is pretty high
what weight did you input?
the g-tech says to start with the gross weight and subtract for missing passenger - this software says to just input a weight - this is a critical component for accuracy though
starting with 3086 curb weight (add 66lbs for a tip), it should be about 3275lbs for a manual hatchback, and about 3430 for a standard cab - this presumes a full tank of fuel, a driver of 150lbs (add or subtract as needed), and about 40lbs of junk in the car - this figure may actually be very low though, as i have seen 75 lbs of junk stuffed into the cubbies and tire area - big speaker boxes get heavy too
and don't forget aftermarket tires and wheels are usually heavier than stock - add that in too
i'm looking forward to playing with this thing this week myself, and comparing it to the g-tech - just haven't had time yet
07-30-2008, 11:13 AM
