04-11-2011, 12:40 PM
A warning to anyone using the wind deflector. At first it seemed the top could go up and down with the deflector installed. Unfortunately, I found this wasn't true. I put my top down for the cruise up Hwy. 25 on my way back from Paso Robles (great time!). I was admittedly lazy and decided to run the 60 mile stretch without hooking up the boot which also requires undoing the deflector to get the boot on. This was the first time I had lowered the top for any extended period of time without first uninstalling and re-installing the deflector. When we got to 101, I put the top back up and found that it had torn in the same place on both sides! After I got home I checked it out closer. It appears that when the top is lowered with the deflector installed, the lower part of the deflector, (the half that makes a screen "shelf" behind the seats), restricts the top from seating all the way down, causes the mechanism to push harder into the top material and results in very clean 2 inch long tears, (almost like knife cuts), on either side of the top! Yuuuccchhhh! So now I guess I'm in the market for a new top. Boy, that wind deflector was expensive! Oh well, at least I can see about following Flash's lead and getting a zip out window. (Flash: how did that work out once you drove at speed with it open?).
Any suggestions on where to get a new top would be greatly appreciated. I'm hoping it won't be too difficult to find one in dark blue.
Bill
Bill
