Thanks Waylander, it's okay all the hardware is in place, but I may buy item 17 at some point as I had to take to the 944 mounting with an angle grinder and a lump hammer, (the long bracket, item 16, fitted just fine).
If nothing else I realised how slack my throttle cable was, so adjusted that and the servo cable at the same time.
Spent most of today upside down in one foot-well or the other, attaching the servo cable and/or searching for the elusive loom/sockets/ or a way through the fire-wall.
Couldn't spot either plug/socket for the loom so eventually gave up and searched for a way through for my cable. Again nothing obvious, no spare grommets and those that I poked at were full. Eventually found a grommet with plenty of space around it which feeds the heater blowers; located above the clutch pedal (LHD).
So that's where I'm at now, about to solder the two ends, switch it on and see if it smokes!!
I won't test drive tonight, too tired, the steering wheel is off, and I fancy a sit down (or is that up??) and a glass of wine. So we'll see what tomorrow brings. Given the volume of negative comments about 968 and 944 cruise control I'm prepared for disappointment, but no worries, that just means more hurdles until it works.
Again, thanks for your support. Cheers, Robert
