10-21-2025, 06:28 PM
Once again I have been trying to fix a wiper system that has lost the intermittent and low-speed functions. I have been down this road here before, eventually solving it in a manner that now escapes me. I am 87. I first lifted the front edge of the plastic panel that covers the heater system, wipers, etc. in the engine bay. My intention was to disassemble the wiper switch connector mounted on the right side (viewed from the front) of this area with the intention of putting a bit of dielectric grease on the connecting points. There are six of these, and upon disassembly they can splay in various directions. I clearly did not get them back in the right order. Upon reconnecting the battery and switch, I operated the wiper motor and got high speed action followed by a blown 30-amp fuse (no. 24).
I assumed that if I placed the two sections of this connector in the same relative positions, top up, the six wires would match position. They not only don't, they are not the same color in the top and lower sections. Aside from the brown, ground wire, present in the upper left position with the parts vertical, none of the wires are matching colors. I'll try to illustrate this by showing a text rendition of the wires of the lower connector on the left, the upper section on the right.
First we look at the wires on the left side lower half of the connector (goes to motor) and the left side of the upper connector (to wiring harness). For reference, the wires emerge at the BOTTOM of the lower section, from the TOP of the upper section when viewed in that orientation.
Left side, top to bottom
Brown/Brown
Blue/Green
Green/Brown and White
Right side, top to bottom
Red/ White and Black
Blue/Yellow and Black
Green/Black and White
If this seems challenging, writing it was no fun either. In any case, the brown ground wires match. Nothing else. I have 944 shop manuals and 968 parts/wiring discs that don't work in our current computers. Yeah, I wish I hadn't opened this can of worms.
Brown/Brown
Blue/Green
