Just a quick check here to make sure the alignment will fix everything. After changing my suspension and lowering the car to the M030 height I noticed that the front wheels have a lot of negative camber, more than the eccentric nuts will correct IMHO. I assume when they do the alignment there is an adjustment on a steering component for large scale rough adjustments?
there is only the one eccentric for front camber. lowering a car automatically increases negative camber, and alters toe. you need an alignment after doing that. the same goes for the rear.
Yea, I was going to get a full alignment as soon as the car was back "together". I was just worried when I rolled it out the other day and looked at the front. It looks like there is a 500 lb. gorilla sitting on the hood according to the wheel camber. Yea, I know, cut out the crack as it doesn't go well with a single malt.
